Lennox Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 08:22 PM   #1
I have a G23Q3 4-100-6. The blower will not come on in auto and the furnace does not stay on for more than a couple of minutes without the blower. it will work if i keep the blower on in manual and just leave the blower on all the time. do you think i need to replace the blower control board? is this a hard job?
Mphawki is offline   Reply With Quote
Old 02-29-2012, 08:27 PM   #2
HVAC Tech/ Browns Fan
Its going to be fan relay. Control board is going to need replaced. Google lennox part plus and you be able find the part.
Tator1076 is offline   Reply With Quote
Old 02-29-2012, 08:41 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Until you replace the board leave the thermostat fan selection in the ON position and you should be able to have heat.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
ben's plumbing (02-29-2012)
Old 02-29-2012, 08:52 PM   #4
Very simple to change.
Old 03-08-2012, 11:56 AM   #5
Thank you for your answers so far!!!
I replaced the control board and still have the same problem - the cold air return fan is not coming on in auto, but seems to be fine in the on position and the fan blowing continuously.
Any other suggestions??
Thanks!!
Old 03-08-2012, 01:57 PM   #6
how
Rewards Points: 1,104
Weird furnace fault.
Your thermostat circuit through "G" on the board does turn on the fan but the timer control & fan relay on the board does not.
What is the led diagnostic light showing?
The usual things that would turn on the furnace fan or not, after the ignition sequence, are integral to the mother board.
how is online now   Reply With Quote
Old 03-08-2012, 02:27 PM   #7
Thanks for replying How!
The diognostic lights both just blink steady, which i am pretty sure is normal operation. Could it be the blower motor capacitor? what would be the symptom if this capacitor went bad?
Thanks for your help!
Old 03-08-2012, 04:01 PM   #8
how
The motor, capaciter, motor leads or their connections to the board could be questioned Except they are already working OK through a thermostatic fan on call.
The other oddity is when you call for heat and the motor doesn't come on, the furnace should overheat, limit out and produce a led code for an open limit.
I think what you are saying is that as soon as the boards timer attempts to turn on the fan motor, the burners shut right off. Everything keeps pointing back to a faulty board which is little comfort to you with a brand new board.
Your furnace manual should list the adjustable settings on the board for how long the delay is before the fan comes on. When you confirm the length of that delay setting on the board, is it the same length of time that the burners are running?
Old 03-08-2012, 04:35 PM   #9
I had to go from a surelight 24L8501 control board to a 83M00. The boards are not quite the same, but i think i got it right - the only wires that i wasn't sure about were the 3 that went from the 120 vac return neutrals on the existing board to the replacement board - the instructions were not specific about where these neutral wires had to go. would those wires possibly be causing issues?
Old 03-08-2012, 04:48 PM   #10
how
No. but one of the lennox sharp shooters around here may have some info on the differences between those two boards.
In the meantime follow through on answering posting 8 and make sure all your ground lines on the furnace are completely tight as that can cause damage and erratic actions to boards.
Old 03-09-2012, 09:39 AM   #11
Thanks How for staying with me!
I feel a little stupid... I ended up taking the flame sensor out and cleaning it up - now everything appears to run good. A hard lesson to learn - i did not need to spend $179 on a new control board. Anyway thanks for the responses!!
Old 03-09-2012, 11:05 AM   #12
how
I'm pleased that it's working....
It doesn't really explain why your board didn't show a diagnostic code for a faulty ignition/ sensor unless your access to that board is by opening a furnace door with a powered door switch?
Lennox 80MGF gas furnace question pdxsk HVAC 19 12-12-2014 03:04 PM
Wiring question for Trane furnace rvmeush HVAC 1 02-27-2012 09:04 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Furnace port, and combustion chamber crack question. cjf1980 HVAC 0 07-27-2009 09:23 PM
Electric Furnace question whatsthis HVAC 32 04-08-2009 07:39 AM
