Lennox Furnace - Primary Or Secondary Limit Switch Open - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 06:08 PM   #1
Lennox Furnace - Primary or Secondary Limit Switch Open
My furnace stopped working today. It will turn on for a few seconds and then back off again, occasionally turning on for closer to a minute. The lights indicate that a limit switch is open. I've read enough where I think I can figure out if the limit switch is the problem by taking out the wires and bypassing the switch to see if it works and then just get a new limit switch. I don't know what the limit switches are, however. Can anyone tell if this is a good idea, and where in the attached pictures the limit switches are that I should be testing?
Lennox Furnace - Primary or Secondary Limit Switch Open-wp_20121212_019.jpg   Lennox Furnace - Primary or Secondary Limit Switch Open-wp_20121212_020.jpg
georgemeaders is offline   Reply With Quote
Old 12-12-2012, 06:11 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 180
Where is the picture. Go to (Go Advanced- manage attachments) to upload one. What is the complete model # of the furnace and serial #. Several Lennox techs here.
Old 12-12-2012, 06:28 PM   #3
Sorry about that, one image is attached now. I will have to wait until I get back from work to check on the actual model # of the furnace in question, unless one of the pictures I took this morning has the model # included.
Old 12-12-2012, 07:02 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 180
Looks like a counterflow/down flow G24 which is a VERY nasty furnace to work on. Limit controls are in the fan compartment and you need to remove the venting etc. I would HIGHLY advise you to call an experienced Lennox tech to deal with that problem. Not something I can walk you thru over the internet w/o other problems occuring. Sorry.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (12-12-2012)
Old 12-12-2012, 07:21 PM   #5
Yikes, that sounds nasty. I added another picture of where I think you're referring to. I might go ahead and call the guy who comes out to service it every couple years and see if he can take a look at it. I was hoping to be able to save a few bucks on it, but don't want to risk screwing things up too badly.
The Following User Says Thank You to georgemeaders For This Useful Post:
Tags
furnace , lennox , lennox-no heat , limit switch
Furnace limit switch question (need answer ASAP) Lemkie HVAC 26 12-11-2012 05:58 PM
Where to buy a Lennox limit switch in Pa Blackbirdin HVAC 3 11-07-2012 03:10 PM
Furnace fan won't switch on--unpredictable intermittent problem arvonon HVAC 3 01-22-2012 04:46 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
