Lennox Furnace Not Workikng - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 04:09 PM   #1
lennox furnace not workikng
I have Lennox furnace SLP98UH that was installed in 10/2011. Red light flashing and gives error messages E228 - unable to perform successful pressure switch calibiration and error HA608. I have tried to reset it, push GFI button, replaced batteries in thermostat, checked outside area around the pipe - seems clean. Nothing is working.
frio300 is offline   Reply With Quote
Old 12-29-2012, 04:37 PM   #2
Rewards Points: 614
not even ventor motor .....
carmon is offline   Reply With Quote
Old 12-29-2012, 06:24 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
check the vent pipes outside for blockage and then call a Lennox tech if that fails. Nothng there you can fix yourself and the parts are under warranty.
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Lennox 80MGF-75A Furnace won't ignite NavyAir96 HVAC 1 11-04-2012 07:18 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 06:51 PM
