Old 10-28-2009, 08:15 PM   #16
Originally Posted by yuri View Post
The one above the burners and pushes the smoke to the chimney.
Yep, that one works.
I thought it was called in inducer fan - is it not?
Edit: although it does run, it only stays on for a few minutes after the furnace attempts to start.
Greenlawnracing is offline   Reply With Quote
Old 10-28-2009, 08:24 PM   #17
old pro
ventor fan/inducer fan same fan different techs call it differently. After the ventor fan starts the pressure switch closes and then the igniter is energized. If the switch does not close then the board show an error code. Is that happening? code is on the back of one of the doors. led flashes. Remove the smokepipe from the top of the furnace and look for a dead bird. Yes, I am serious, they fall in and can block the pipe and cause a problem.
Old 10-28-2009, 08:34 PM   #18
Just tried that - no bird, just one dead roach. The fan blades appear to be moving properly.
There is no error code, which confuses me. Because the igniter is not being energized and the gas is not being lit - I would have thought that I'd get an error code.
I did connect my multi meter to the pressure switch. The left lead reads 27v, and the right lead reads .8v.
Old 10-28-2009, 08:44 PM   #19
old pro
You probably have a bad circuit board. It definetley should show you an open pressure switch code. Try cozyparts.com for Lennox parts or a Lennox dealer.
Old 10-28-2009, 08:51 PM   #20
Is there a way I can test the board to confirm its bad before I buy a new one?
Old 10-28-2009, 09:07 PM   #21
old pro
Nope. All the codes should be on the sticker and they never fail to show up on a board. Especially the pressure switch code.
Old 10-30-2009, 12:24 AM   #22
Fixed!
I went to the supply house to get a new tube...they didn't have the exact tube that I broke, just a generic one that wasn't nearly as stiff and had a larger interior diameter.
I had a guy come over to look at it tonight. Before I put the new tube on he had me run a wire into the inducer fan....guess there had to have been something tiny plugging it up. I didn't feel or see anything, but it fired right up.
The high heat tube that Lennox used is different than the one I bought today...the one I got kinks easily and required me to reposition the pressure sensor. Stupid replacement tube from Lennox is $25!
Still baffled as to why I never got any trouble codes.
Old 10-30-2009, 05:41 PM   #23
old pro
That is very strange. Good to know in case I run into one. Probably a bad batch of boards from whomever made them.
Old 10-30-2009, 06:04 PM   #24
Default What do you mean about the tube?
What kind of tube are you talking about that you replaced? I don't think i have ever heard of a high heat tube.
thehvacguy is offline   Reply With Quote
Old 10-30-2009, 07:58 PM   #25
The orange tube is the original one that I tore while removing. It was basically molded to fit perfectly. I replaced it with the black tubing, but it isn't nearly as thick and kinks easily. I had to move the pressure sensor to make it work, and I'm worried that it will melt as I don't know if it can withstand the heat.
I'll spend $25 if I have to...but can you get a replacement somewhere else? $25 from cozyparts just seemed pretty high for a little piece of rubber.
Old 10-30-2009, 08:05 PM   #26
old pro
It is SILICONE hose and not rubber and the stuff costs me about $10/foot. Buy it or it will melt. Too bad you don't live nearby, I have lots of those leftover from other jobs.
Old 10-30-2009, 08:22 PM   #27
Any place I can buy something similar? Like an autoparts store?
Any chance you want to ship me a piece?
Old 10-30-2009, 08:22 PM   #28
So pretty much the tube allows the heat from the vent to flow to a limit switch?
Old 10-30-2009, 08:24 PM   #29
old pro
If it is the right diameter and made from silicone it will work. The Lennox one is better because of the square shape/prevents kinky/kinking.LOL.
The tube goes to a pressure switch which proves the ventor fan is running by the vacuum the fan draws.
Old 10-30-2009, 08:29 PM   #30
The pressure switch is normally open or normally closed?
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here for a second about baffles. These are what we call baffles right here... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
carrier/payne furnace heat exchanger issues gomongo1 HVAC 7 03-19-2009 10:06 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 11:11 PM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 06:06 AM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 06:52 AM
Ducane Furnace - no heat dave_in_waterloo HVAC 2 10-19-2008 10:07 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
