Old 01-24-2011, 03:02 PM   #16
Lennox furnace misbehaving
Update... I had my installer re-do most of the wiring.. there were some errors with the low-voltage setup. Ultimately, the cause of this entire mess was that one of the sequencers was bad (probably from the start) and would not turn on its element, or the one downstream element, so that only one was running on auxillary heat.
The sequencer was replaced and the problem corrected.
Thanks everyone for your help. I am slowly defrosting.
gbwillner is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Portable generator and Lennox furnace joshbloomberg Electrical 7 02-10-2010 11:25 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
