Old 08-07-2011, 08:06 AM   #1
Lennox Furnace Issue
I have an old Lennox Furnace that's about 30 or so years old in a home I just bought. The problem is that when I turn on the AC some times all I hear is this clunking noise coming from the blower motor. When I looked closer the clunking noise is the motor starting for about a split second then turning back off. Some times the blower will get up tp speed for a few seconds then shut back off and some times it works just fine.
Jim DEnault is offline   Reply With Quote
Old 08-07-2011, 08:39 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
30 years old, and showing problems, time to change. Was this not inspected by a home inspector before purchase of the home, or are you living in a rental.
The Following User Says Thank You to gregzoll For This Useful Post:
Jim DEnault (08-07-2011)
Old 08-07-2011, 09:41 AM   #3
Experienced
Jackofall1's Avatar
Welcome Jim DEnault, to the best darn DIY'r site on the web.
Not sure if its worth repairing given its age, but sounds to me like you need a new blower motor. If you do repair it, remove the motor and take it to a place like Grainger and they will match it as best as it can be matched.
Mark
Old 08-07-2011, 10:04 AM   #4
Hvac Pro
It is a belt drive motor and probably the starting switch is shot. Check the pulley on the motor and blower wheel to see if they are loose. Time for a new furnace IMO as the heat exchanger will have cracks at that age. Main blower wheel may have a loose hub also. Not worth spending $$ on. Less than 60% efficient, more like 50%.
Old 08-07-2011, 11:43 AM   #5
The Furnace was inspected. Heat exchanger is not cracked, has a good burn according to the HVAC Tech that looked at it. I plan on changing the unit in the fall, but if I can fix it for a few buck just so I can run the AC I will.
Old 08-07-2011, 11:48 AM   #6
Hvac Pro
Probably just needs a new belt drive motor if that is what it has. Try Acklands/Johnstones/Grainger.
Old 08-07-2011, 05:36 PM   #7
The Unit # is G12q3822 Serial # 5879E03237 Does anyone know if this unit has the Belt Drive motor that was mentioned? I guess I'm still a little confused by the Belt Drive Motor as the unit still runs sometimes.
Old 08-07-2011, 05:54 PM   #8
Hvac Pro
G12 has a direct drive motor. G8 the sister would have had the belt drive. May have a bad fan relay to turn the motor on or bad hub in the blower wheel itself or the thermostat is not energizing the G terminal properly. Need a experienced tech to catch it while it is doing it. If you plan to replace it in the fall I would do it sooner than later. Repairs are going to be $200-$400 depending on what is wrong etc.
Old 08-07-2011, 06:13 PM   #9
Do you know where I can get a fan relay?
Old 08-07-2011, 06:43 PM   #10
Hvac Pro
no. that unit is obsolete and I have not seen one in years. could also be a problem with the thermostat or even the motor itself. one of the windings may be shorting or opening up.
Old 08-07-2011, 06:51 PM   #11
I changed the thermostat so that's not it. It still acts the same way. Is there anyway to jumper the fan switch to see if it is in fact the switch?
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Lennox Furnace in Watchguard mode HardcoreNinja69 HVAC 3 02-02-2011 02:40 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Need help with a Lennox Furnace KCDrew HVAC 1 12-09-2009 06:39 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
