Lennox Furnace Ignitor Switch(?) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 04:46 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 386
On a SERIOUS note we have had a few chimneys get blocked UP from the cleanout with dirt. If the liner is a single wall and goes below ground level thru a masonry chimney which loses its mortar it can rot thru and dirt and water can get in and block it up. Also a liner with holes can mess up the draft/downdraft on windy days and cause pressure switch problems.
Old 01-30-2009, 04:55 PM   #17
JohnH1's Avatar
Had a couple of rotted liners also 4 to 6 year old range. We determoned in both cases it was caused from the owners storing paint materials and such in the visinaty of the furnace. When mixed in the combustion process acid formes and rotted the liners. Both were residential homes. And both owners were the type that never through out anything. Now try getting them to belive this they still dident want to get rid of the paint etc.
JohnH1 is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 04:06 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
1973 Lennox ES2 Furnace Noisy indygo HVAC 1 03-26-2006 07:43 PM
