Lennox Furnace Hose - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 06:26 PM   #16
HVAC Tech/ Browns Fan
If its working ok the way it is right now then leave it alone. I had broke the end and still able put back on and work fine. Heck pull over the pressure switch bracket closer to draft port.
Tator1076 is offline   Reply With Quote
Old 01-27-2012, 06:43 PM   #17
Originally Posted by harleyrider View Post
see post Number 5
I have, and none of them have it.
See posts #13 and #14, it has been found!
jwhvac is offline   Reply With Quote
Old 01-27-2012, 06:44 PM   #18
Yeah it seems to be working fine right now, but I'll probably order it just in case, since it was weakened in the first place which is what caused it to come apart.
Thanks!
Old 01-27-2012, 08:13 PM   #19
Originally Posted by jwhvac View Post
Yes they do, I just called them.
I guess I should have called in the first place instead of browsing the online catalog. It's much easier to find when you have the part number. I wish they had part numbers listed in the owners manual so this task would be easier.
Thank you for the help!
If you don't have a dog I can walk your cat
hvac5646 is offline   Reply With Quote
Old 01-27-2012, 08:16 PM   #20
Lennox G23 furnace intermittent spark ignition carman HVAC 11 12-15-2010 05:41 AM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Lennox furnace ignitor switch(?) TotallyConfused HVAC 16 01-30-2009 04:55 PM
Lennox G11Q3E-110V-6 gas furnace neato5oh HVAC 1 10-07-2006 06:43 PM
