Lennox Furnace Dead - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 10:13 AM   #1
Rewards Points: 5,336
Lennox Furnace Dead
Son has a 2 year old Lennox G50UH series furnace that will not fire up.
Thermostat has new batteries.
There is power to the furnace, from the make up box, through to the transformer.
The gas valve is "on"
Mini breaker next to cover switch is not popped
Both LED's are out(red and green).
It worked fine the first year. Last year it wasn't used and the gas to the house was turned off. House was heated with space heaters due to idiocy of occupants.
Any suggestions?
Ron
B. Franklin 1759
Old 09-21-2011, 10:55 AM   #2
fabrk8r
fabrk8r's Avatar
Does anything happen when thermostat calls for heat? Does inducer fan start?
If both LEDs on circuit board are out there must not be power at the board. Have you checked the low voltage fuse?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-21-2011, 11:06 AM   #3
The furnace is silent when the thermostat is raised calling for heat.
The fuse is intact.
I'm going back with a meter to see if there's voltage coming out of the transformer. I'll also check the fuse for continuity in case it's not connected at an end.
Ron
B. Franklin 1759
Old 09-21-2011, 12:47 PM   #4
Rewards Points: 6,652
I would try connecting the thermostat with a short stub of wire, right at the furnace, and see if you can get a call for heat. It is also possible, that the thermostat is fubar.
Old 09-21-2011, 02:31 PM   #5
I tried another thermostat an hour ago, no luck. I checked the transformer and had no reading coming out to the mini breaker on the low voltage side. I'll try replacing that. After that, it's a service call.
Ron
B. Franklin 1759
Old 09-21-2011, 05:53 PM   #6
Do you have high voltage at the transformer terminals of the control board?
Old 09-21-2011, 06:26 PM   #7
There is 110 volts on the line side of the transformer.
Ron
B. Franklin 1759
Old 09-21-2011, 07:13 PM   #8
I'm Your Huckleberry
Rewards Points: 2,270
Turn the stat to Auto and Cool and drop the temp. If the cooling works then it's not the transformer.
Doc Holliday is offline   Reply With Quote
Old 09-21-2011, 07:24 PM   #9
Will this just operate the fan in the furnace? He has no central A/C.
Ron
B. Franklin 1759
Old 09-21-2011, 09:02 PM   #10
AKA HVACTECHFW
Rewards Points: 1,208
If you have no LED lights that should be flashing slow without a call for heat, then you either have no 24V or you have a bad control board. WIth a call for heat the LED lights should flash fast.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Doc Holliday (09-21-2011)
Old 09-21-2011, 09:03 PM   #11
Put stat to fan on. If anything works than low voltage is present. Tyranny should be good then.
Old 09-21-2011, 09:07 PM   #12
Transformer gives stat control voltage so if any or one call works tyranny is good.
Old 09-21-2011, 09:08 PM   #13
AKA HVACTECHFW
How do you know that G is wired?
IT IS WHAT IT IS
Old 09-21-2011, 09:12 PM   #14
How much wood could a wood chuck chuck if a wood chuck could chuck wood?
Old 09-21-2011, 09:16 PM   #15
Tech, I don't know.
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 07:03 PM
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 11:43 AM
The blower on my Lennox furnace won't shut off kgduda HVAC 8 10-31-2010 02:31 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Lennox furnace problem devgill08 HVAC 5 12-11-2008 08:38 PM
