Lennox Furnace Burner Won't Stay On - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-13-2014, 06:55 PM   #46
My Furnace Lennox G51MP is not staying ON
I own a lennox G51MP and is nor working properly, I Called a company to see what was wrong and they said that is the Control board or the surface ignitor.
Whe I turn on the furnace, the furnace works and it reaches the temperature that I have set on my Thermostat but when it calls again for heat the induction motor stays on and it does not shut off and it gets very hot as well.
I would like to know if soembody has an Idea on what's wrong with this furnace the comoany that I called wants $1,300. to fix my furnace this is alot of money this furnace is only 7 years old, I know that is something simpler that what they are talking about also the person that came to see the furnace told that it could be the pressure switch this furnace has two.
Hopefully somebody will answer my queistion and concerns
vbeltran is offline   Reply With Quote
Old 03-13-2014, 06:56 PM   #47
Old 03-14-2014, 09:00 AM   #48
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Is it the induction motor that won't shut off and gets hot. If so the the relay on the control board is sticking on and you need a new board. It is easy to change and you can get it from cozyparts.com.
Old 01-02-2015, 06:37 PM   #49
Rewards Points: 2
Thumbs up
The Red Tube!!
Just wanted to say thank you for this thread.. Spent a couple days troubleshooting my issue of the burners going on and off. I cleaned the soot off the sensor rod, checked ventilation blocks, but cleaning the pressure switch tubes worked like a charm. There was a lot of build up in there! Was on my way to hiring someone to come out! Thanks again
acowlaughing is offline   Reply With Quote
Old 01-02-2015, 09:30 PM   #50
Hvac Pro
yuri's Avatar
Yur Welcome
Old 02-05-2015, 08:59 AM   #51
Rewards Points: 2
Talking
Thanks, Yuri
Thanks, Yuri. I cleaned the flame sensor and now we have heat! You are still helping people 7 years after your original post!
Kansas City, 2/5/15, 4 degrees.
cmccluer is offline   Reply With Quote
Old 02-05-2015, 09:18 AM   #52
Hvac Pro
yuri's Avatar
It's an Oldie but a Goodie
Old 01-02-2016, 04:36 PM   #53
Rewards Points: 2
Smile
furnace did not stay on
the information received did work by cleaning the furnace flame sensor:smile
hewley marks is offline   Reply With Quote
Old 01-02-2016, 07:25 PM   #54
Dave Sal's Avatar
Rewards Points: 592
Had the same issue as the original poster a few days ago and found this thread. Furnace is back running once again. Thank you Yuri for sharing your knowledge and saving us DIY'ers from the cold.
Dave Sal is online now   Reply With Quote
Old 01-02-2016, 10:38 PM   #55
Hvac Pro
yuri's Avatar
Glad 2 help.
Tags
furnace repair
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
