Old 12-14-2010, 12:48 PM   #1
lennox furnace
My lennox furnace will only work when the fan is on all the time. It will not come on when it is set on automatic fan. Do I need a new circuit board? Can I install it myself?
foot is offline   Reply With Quote
Old 12-14-2010, 05:09 PM   #2
lennox furnace
The way you test is to turn the heat on. Put a meter on the blowers heating speed tap and neutral. 45 seconds after the burners ignite you should have 120 volts present. No voltage is a board issue, yes voltage but no blower is a motor issue. Yes you can replace part yourself.
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
