Lennox Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 07:47 PM   #1
Lennox Furnace
We have a Lennox G 2003/4E-100-3 Furnace. The problem we are having is that the pilot lights, the burners light, the blower comes on just like normal. But after a few minutes of running, the burners starts cutting in and out repeatedly.
wadey324 is offline   Reply With Quote
Old 04-03-2011, 07:59 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
Change your air filter lately? May be overheating. May sure all your vents are open.
Old 04-03-2011, 08:06 PM   #3
filter was changed this morning and all the vents are open
Old 04-03-2011, 08:24 PM   #4
Hvac Pro
yuri's Avatar
May want to call an experienced Lennox tech. The heat exchanger may be cracked and opening up after it heats up. Not an easy furnace to troubleshoot if you don't have LOTS of experience with them. Not something I can walk you thru over the net.
The Following User Says Thank You to yuri For This Useful Post:
wadey324 (04-03-2011)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
