Lennox Filters - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 12:18 PM   #1
Lennox Filters
I'm told that Lennox has discontinued their 20x26x5 filters, especially in the MERV 16 category. Can anyone confirm this?
The furnace is only about 10 years old and if this is the case I find it poor practice from Lennox to leave an installed base of customers stranded without proper sized filters.
holocron is offline   Reply With Quote
Old 12-30-2012, 01:23 PM   #2
Rewards Points: 196
Good ole Lennox! You should be able to find an aftermaket filter that is comparable online or thru a contractor.
HVACTECH96 is offline   Reply With Quote
Old 12-30-2012, 06:21 PM   #3
Rewards Points: 616
use a 20 - 25 .... fill the 1' gap.... all should be fine.... just take a t.d.
carmon is offline   Reply With Quote
Old 12-31-2012, 09:13 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,252
That filter is specific to the PCO pure air system and they have it with the replacement kit that goes with the PCO system and comes with a catalyst and UV bulbs which we recommend you change once a yr. If they delete it then I imagine they will have a factory 1" insert to shove in there to do the job or you can make one out of a wood stick.
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
Q for Lennox iComfort users or Lennox Pros klingon HVAC 8 02-11-2012 06:29 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 04:01 PM
Lennox Furnace filters DonEllison HVAC 4 02-19-2011 02:01 AM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
