Lennox Fan Blower Motor - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 05:00 PM   #16
Rewards Points: 117
So I need a manometer to do this??
How do I do it once I have the meter or is it to complex??
mustang64 is offline   Reply With Quote
Old 03-09-2013, 05:18 PM   #17
how
Rewards Points: 1,104
I might have mis read your earlier posting
If you moved the taps that are used to measure the gas pressure and then screwed then back in, and they are not leaking gas, everything is fine.
If you removed some gas adjustment covers and then adjusted a screw within, then testing is needed.
how is offline   Reply With Quote
Old 03-09-2013, 05:18 PM   #18
An old Tradesmen
Rewards Points: 7,370
Originally Posted by mustang64 View Post
Hello beenthere,
For a reason that I won't get into, I moved the inlet and out pressure taps on my Honeywell gas valve. I turned them back to where I think they were set.
If that is not the case, could I have affected the gas flow a great deal??
Do I now need to get an HVAC guy in to check the gas flow??
Thanks.
Could be over or under fired then.
It would be best to have them checked, as no way to know how it is set now.
Old 03-09-2013, 08:25 PM   #19
Rewards Points: 117
Thank you for the help beenthere.
Have a good evening.
Old 03-10-2013, 10:00 PM   #20
Rewards Points: 117
Sorry beenthere for the misunderstanding.
All I touched was the inlet and outlet pressure taps on the gas valve.
So are you suggesting that I should have them tested (manometer) or am I fine with the way they are??
Thanks.
Old 03-10-2013, 10:03 PM   #21
An old Tradesmen
If you didn't touch/adjust the pressure screw, no need to have it checked because you touched the pressure port plugs.
Old 03-11-2013, 03:10 PM   #22
Rewards Points: 117
Hey beenthere,
Are these pressure ports like set screws with an allen key socket??
That's the description of the two screws I touched.
If there are, I should tighten them all the way because that's where gas can escape??
Thanks.
Old 03-11-2013, 03:37 PM   #23
Rewards Points: 117
Ports are fine.
Thanks for all the help from this chat.
Great website!!!!!
Old 03-11-2013, 03:48 PM   #24
An old Tradesmen
Hey beenthere,
Thanks.
Yes, those are the ports where a manometer would be connected to in order to check gas pressure. As long as they are tight, your good.
Old 02-05-2014, 05:46 PM   #25
Rewards Points: 117
Hello can I ask a question here about a gas dryer??
Old 02-05-2014, 08:04 PM   #26
An old Tradesmen
Start your own thread in appliances about it.
ECM Blower Motor bad Dragons Den HVAC 21 01-04-2014 07:21 PM
Help diag. blower motor issue in Lennox furnace partsace HVAC 12 01-23-2012 02:59 PM
New AC/furnace blower motor will not turn off Larry2010 HVAC 0 06-08-2010 08:46 PM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
Lennox blower motor overheating northface HVAC 3 05-15-2009 07:27 PM
