Lennox Elite Series G26 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 04:04 PM   #1
lennox elite series g26
My problem with this furnace g26 series is that the ignitor starts to glow but the burner wont come on. then it starts back over again.The 2 green lites start to flash ( slow back and forth) can you tell me what I can do before I call a repair man. Thank you so much
moon4040 is offline   Reply With Quote
Old 10-20-2010, 04:58 PM   #2
An old Tradesmen
Rewards Points: 6,548
The flash is an error code. Count how many times it flashes. And then look the code up. Code legend should be on panel.
The Following User Says Thank You to beenthere For This Useful Post:
moon4040 (10-21-2010)
Old 10-20-2010, 06:02 PM   #3
Slow back and forth flashing is locked out due to ignition failure 5 times in a row. It will stay in that mode for one hour then attempt to light again.
The hot surface ignitor wouldn't come on if a safety was tripped so you're looking at a gas problem. Could be the control board not sending 24 volts to the valve, a bad valve, gas shut off, spider egg sacks in the orifices ect. How deep you're willing to check before calling for repairs is up to you.
The Following User Says Thank You to Marty S. For This Useful Post:
Old 10-21-2010, 10:53 AM   #4
lennox g26 furnace = I checked the 2 wires going to gas valve ,I got power comming from them . Could that plug on the gas valve go bad . If so I will check to see if power is going through the plug, if power dont go through it is the plug bad
Old 10-21-2010, 06:16 PM   #5
That's part of the gas valve, not a seperate replacable part. Sounds like it's time to buy a new valve if you made sure there's gas coming to the valve but not getting through.
HELP- Lennox Elite Series Furnace # M/N 90UGFA3-75-5 baironhorse HVAC 41 10-22-2014 04:59 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 03:49 PM
Lennox Elite Water Gurgle n2omike HVAC 3 10-16-2010 06:32 PM
Lennox Elite Series - right fast flashing light. Need Help natemast HVAC 4 10-03-2010 05:55 PM
Need help getting just the fan to run on a Lennox Elite BigEdgar HVAC 16 08-01-2009 08:38 PM
