Lennox Elite G51MP Series - Combustion Air Inducer Running - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 02:20 PM   #1
The Combustion Air Inducer continues to run after the set thermostat temp is reached and when it tries to start again to reach the set room temp I get an error code Left/Red LED (not lite) and Right/Green LED (slowly flashes). After an hour or so with the power off I turn power back on and it runs for a few hours and happens all over again..
Thanks For Your Time - Any suggestions?
LennoxElite is offline   Reply With Quote
Old 12-10-2010, 02:55 PM   #2
I suspect the inducer relay on the board is sticking. Probably need a new board.
SKIP4661 is offline   Reply With Quote
Old 12-10-2010, 06:24 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 382
Yep. Try cozyparts.com for Lennox parts. Need complete model AND serial # for them.
Old 12-11-2010, 05:55 AM   #4
Thanks for your quick response! I just noticed this only happens when the thermostat is set on a higher temp (67 Degrees or higher) and needs to run more being winter outside.. But when it is set to a lower temp (65 Degress) it runs fine...
Thanks For Your Time - Any other suggestions?
Old 12-11-2010, 06:55 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 382
Max no difference the temp setting. Runs more often at higher temp and odds of it stickin are higher. Will get worse soon and Xmas is comin.
Old 12-12-2010, 09:01 AM   #6
Thanks For Your Time And Advice !!!
Old 10-06-2012, 10:05 AM   #7
Did this solution work?
Hi, I have the exact same problem with my Lennox G51MP furnace. Did this solution work? Was it the "board"? Is the board part of the "Combustion Air Inducer"?
I was told I need a new "Combustion Air Inducer" which is running rough, but I don't really trust the shady repair company *long story* so I want to make sure I order the correct part.
Thank you!
cristnia is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Lennox Elite Series - right fast flashing light. Need Help natemast HVAC 4 10-03-2010 04:55 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 04:13 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
