-   -   Lennox Elite G51MP Series - Combustion Air Inducer Running (http://www.diychatroom.com/f17/lennox-elite-g51mp-series-combustion-air-inducer-running-89264/)
LennoxElite 12-10-2010 03:20 PM
The Combustion Air Inducer continues to run after the set thermostat temp is reached and when it tries to start again to reach the set room temp I get an error code Left/Red LED (not lite) and Right/Green LED (slowly flashes). After an hour or so with the power off I turn power back on and it runs for a few hours and happens all over again..
Thanks For Your Time - Any suggestions?
SKIP4661 12-10-2010 03:55 PM
I suspect the inducer relay on the board is sticking. Probably need a new board.:eek:
yuri 12-10-2010 07:24 PM
Yep. Try cozyparts.com for Lennox parts. Need complete model AND serial # for them.
LennoxElite 12-11-2010 06:55 AM
Thanks for your quick response! I just noticed this only happens when the thermostat is set on a higher temp (67 Degrees or higher) and needs to run more being winter outside.. But when it is set to a lower temp (65 Degress) it runs fine...
Thanks For Your Time - Any other suggestions?
yuri 12-11-2010 07:55 AM
Max no difference the temp setting.:no: Runs more often at higher temp and odds of it stickin are higher. Will get worse soon and Xmas is comin.:whistling2:
LennoxElite 12-12-2010 10:01 AM
Thanks For Your Time And Advice !!!
cristnia 10-06-2012 11:05 AM
Did this solution work?
Hi, I have the exact same problem with my Lennox G51MP furnace. Did this solution work? Was it the "board"? Is the board part of the "Combustion Air Inducer"?
I was told I need a new "Combustion Air Inducer" which is running rough, but I don't really trust the shady repair company *long story* so I want to make sure I order the correct part.
Thank you!
