Lennox Cooling Btu - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 09:02 PM   #1
Lennox Cooling Btu
I'm looking at a new Lennox system and I know the XC14 is a better condenser, but why such a difference in cooling btus?
Lennox XC14 paired with CBX27UH-060 You get 56,500 btus cooling
Lennox XC13 Paired with CBX27UH-060 You get 60,000 btus cooling
dbmet is offline   Reply With Quote
Old 06-08-2011, 05:42 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
You will have to talk to an engineer at AHRI or Lennox for all the info. Depends on the matchup of the type of evap coil with the condensor. There are A coils and case coils etc. They design the unit to meet the SEER rating for efficiency and to be eligible for any gov't rebates not to get an exact tonnage/btu's. Never have in the last 50 yrs. The compressor may not be exactly 5 tons as they technically rate them in horsepower. Gets to be a VERY in depth conversation that only engineers understand. You never get the exact Btus as the amount of freon in the lineset varies with the length of it and how close to prefect the installer can get the subcooling/approach temp. SEER is what it costs to run irregardless of the Btus/tonnage and that is what I would be concerned with. If a car is rated for 50mpg and its sister is rated for 48mpg you would buy the 50 mpg as it costs less to run. Ie Ford Escape and Mazda Tribute, almost the same vehicle using interchangeable parts but one may get better mileage.
Lennox XC21 Not Cooling - Please Help! honda03v6 HVAC 3 06-07-2011 06:00 PM
lennox heat pump cooling probs greaseking76 HVAC 1 05-28-2011 07:26 AM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
lennox g20 whisper heat cooling mood cargom HVAC 0 09-25-2010 09:41 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
