Lennox Condenser Hums - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 10:32 PM   #1
Hello. The A/C has been down all day, and when I got home from work, I went outside and the condenser was humming, but nothing was moving. Any ideas on where to start? Someone mentioned to look at the start capacitor. Any other ideas?
The fan works. The condenser was hot to the touch on the top of the unit. It's not off at the breaker.
thanks
brokenhammer is offline   Reply With Quote
Old 05-23-2010, 11:02 PM   #2
Houston204's Avatar
Rewards Points: 556
If the fan spins freely with power removed, replace the run capacitor for the condenser fan motor.
(Probably a dual capacitor)
Houston204 is offline   Reply With Quote
Old 05-23-2010, 11:10 PM   #3
Houston! Thanks for the info. I'll try that tomorrow morning. I appreciate the help.
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Condenser freezing zep HVAC 2 01-30-2010 08:04 PM
help with old lennox AC unit 2.5ton northcoastmech HVAC 1 07-12-2009 12:48 PM
Lennox HS29-311-3P Air Conditioner Not Working olgranddad HVAC 13 06-23-2009 11:39 AM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
