LENNOX C23-41-1 Furnace IGNITOR IS NOT ENERGIZED - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 12:59 PM   #1
When I turn the heat on the combustion air blower runs, but ignitor won't turn red. The 2 LEDs on Controller borad are normal (Both SIMULTANEOUS FAST FLASH). After about 2 minutes, the fun stops and the LED2 becomes slow flash and LED1 off. According to the manual, it means Pressure Switch fails. I have 2 zone systems so there is another Lennox C23-51-1 (4 ton) there next to the C23-41-1 (3 ton). I switched controller, ignitor and pressure switch. It still has the same problem. I found that on the working C23-51-1, the 2 wires connected to the Pressure Switch both have about 25 vac to ground, but on the non-working furnace, the front wire has only about 1 vac. Any idea what the problem could be?
Thanks a lot.
xuzhang is offline   Reply With Quote
Old 10-27-2011, 02:51 PM   #2
Thanks a lot.
It is fixed. It was the Pressure Switch hose that connect to the fan, the small hole on the connector was blocked. Thanks.
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 02:49 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 08:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 05:51 PM
