Lennox Boiler Will Not Light - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 12:24 PM   #1
Lennox Boiler will not light
Its a lennox boiler with a honeywell thermostat. They were both installed in 2009. I've never had any problems with it until now.
My heat won't kick on. Its about 57 in my house right now and if I mess with the thermostat it will sometimes kick on but only enough to raise the temp a few degrees. I have it set at 80 right now (my normal setting is 65). I checked the wire connections in the thermostat and where they connect to the boiler, as well as any other wire connections on the boiler. The gas, is on the thermostat is set to heat, the fan is on auto, and it also reads heat is on. The unit is about 3 years old. Any suggestions?
skidex is offline   Reply With Quote
Old 12-09-2012, 01:55 PM   #2
An old Tradesmen
Rewards Points: 6,870
Look at the flashing error LED in the blower panel, and look what error it is indicating on the back of the blower panel.
PS: You have a furnace, not a boiler.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (12-09-2012)
Old 12-09-2012, 03:48 PM   #3
Rewards Points: 1,294
Yes, please verify that you have either a boiler (no fan) or a furnace (Fan). Boilers heat with hot water furnace creates hot air thru vents/registers
danpik is offline   Reply With Quote
Old 12-09-2012, 06:21 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Unless its plumbed into an air handler
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Raypak boiler pilot light problem Ballastar HVAC 5 01-13-2012 12:18 PM
Boiler wont light.. Flywaver General DIY Discussions 4 12-27-2010 11:08 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
pilot light on crown aruba boiler mazzonetv Plumbing 1 05-28-2009 10:13 AM
