Lennox Blower Motor Overheating - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2009, 03:31 PM   #1
Lennox blower motor overheating
Hi, i just installed two new Lennox package units and im having the same problem with both, the blower motors keep heating up and shutting down.
Called the manuf. and they sent me two new motors, changed them both and still have the same problem. motors amps rating is 8.3 to 8.8 and im getting a reading of 28 to 31 amps on one unit. The other unit is getting 12 to 13 amps which is letting it run a bit longer, but either way its not right.
Can anyone please help me with this problem?? its hard to believe that 4 new motors are bad, so i think i have a different problem.
Units are connected to correct size wiring with correct size disconnects and fuses, rotation of the fan is correct, compressors working fine. belt on unit is perfect, I also tried making the belt a bit loose to check the amperage and the more loosened the more the amps dropped but it came to a point where the belt was no longer doing anything and i had 18 amps
thanks.
northface is offline   Reply With Quote
Old 05-15-2009, 03:56 PM   #2
What voltage and what freq. goes into the motors?
While the motors still work, measure the DC coil resistances and compare with the manuf's spec's. With 18A no load this motor may already be whacked.
Do the motor shafts spin freely?
Old 05-15-2009, 05:24 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
Do you have correct voltage to the motors? Is the ductwork open and airflow proper? No fire damper in ductwork closed/blockage causing no airflow? Lennox has a 1-800 tech support #.
Old 05-15-2009, 07:27 PM   #4
HVAC / Plumbing
My thoughts also... return/supply air flow
kenmac is offline   Reply With Quote
Lennox G12 Blower Motor Problem jimvh2 HVAC 15 03-19-2016 11:27 AM
Lennox CBX32MV: DIY blower speed adjustment? gp_wa HVAC 3 11-02-2008 10:17 PM
Lennox G10 Blower Control s6skuzy01 HVAC 1 10-12-2008 06:04 PM
No Blower (Lennox G11Q3E) "Technical" Terry HVAC 3 04-03-2007 07:54 AM
Troubleshoot Blower Motor - Lennox LongShot HVAC 2 12-29-2006 06:30 PM
