Lennox Blower Drawing Too Much Current On Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 12:16 PM   #1
Lennox blower drawing too much current on starting
Good morning and Happy new year to everybody....
My problem is the following : i have a Lennox elite serie 2003 oil furnace (a big one 140000btu,I think) which is causing me headaches:
After 1 and half year use ,the relays under the control board started to desolder in the blower fan circuit .The fan was set at high speed because the house is big...
After resoldering them correctly the blower works fine till now.....
Same thing,relays need to be resolder but also the wires which plugs for the blower fan get burned....
After fixing this,i get the following result : difficulty to start the blower (take like 6 or 7 seconds to reach its speed). During this,high starting current of course !! After it starts,current is 6,4A. I check the capacitor it seems alright and test around 6 microfarads.
Is this value OK. For now i set the fan continuously ON operation and medium speed....
I am vrey anxious about this because we have very cold weather at this time.
Unhappily i cannot find a model or serial number. The motor fan is direct drive but also i cannot read the nameplate.
Assistance would be greatly appreciate.Thanks in advance
naelec is offline   Reply With Quote
Old 01-01-2013, 12:24 PM   #2
HVAC Tech/ Browns Fan
Check starting rotor amps. If its over 10 or higher amps motor winding are going.
Tator1076 is offline   Reply With Quote
Old 01-01-2013, 10:58 PM   #3
Rewards Points: 614
what is a starting rotor amp......
carmon is offline   Reply With Quote
Old 01-02-2013, 07:15 AM   #4
What's the rating printed on that capacitor? Six isn't sounding right for a 3/4 or 1 HP motor.
Old 01-02-2013, 08:27 AM   #5
Rewards Points: 614
the motor should also have what capacitor is required stamped on it as well......
Old 01-02-2013, 10:36 AM   #6
Thanks to everybody who answered me....The value on the capacitor is erased and nothing written on the motor...
The lennox oil furnace is elite and model 023Q5-140/154R-5A
I dont have any contact at Lennox, so if somebody could tell me the right value of the capacitor and the motor,or who to call at lennox or a way to obtain this informations, or a internet website lennox parts,etc,....it would be very helpfull
Huge thanks
Old 01-02-2013, 08:00 PM   #7
Rewards Points: 614
6 microfarads is not a common capacitor here...... what is the motors h.p.
Old 01-03-2013, 06:12 AM   #8
the cap needed is stamped on the tag on the motor probably a 15 or 20 as lennox uses big caps on blwers
mrairflow is offline   Reply With Quote
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
lennox elite series blower runs but no heat? Rein HVAC 8 02-22-2012 05:12 PM
Help diag. blower motor issue in Lennox furnace partsace HVAC 12 01-23-2012 03:59 PM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
Lennox A/C unit not starting netddd HVAC 8 08-17-2010 12:30 AM
