Old 09-08-2010, 10:26 AM   #1
Lennox Air Handler struggles to start?
I have a Lennox variable speed air handler that was installed 1 year ago. Occasionally when the unit kicks on the fan does not start immediately. Instead I get anywhere from 3 to 30 seconds of the handler making a loud thumping noise. Almost as if the fan motor isn't starting up correctly? It will thump about 5 times then briefly pause. Then thump 5 more times then pause. It will continue to do this over and over until the blower kicks on. At that point everything sounds and behaves normally.
I had the AC company come out and inspect it and they state that everything is just fine. All of my various pressures and voltages were A-OK. I explained the noise to them (naturally it didn't do it the 2 times they turned it on) and they said it was perfectly normal. Eventually I will get used to the noise and won't even notice it.
I am just curious if this is indeed normal?
yelowsnw2 is offline   Reply With Quote
Old 09-08-2010, 05:29 PM   #2
Hvac Pro
Variable speed motors will rock/thump on startup and that is the nature of the motor and normal. It is charging capacitors internally and determining an initial speed setting and getting ready to ramp up in speed. Part of the PWM Pulse Width Modulation process.
Lennox Air Handler vs Furnace armsteadj1 HVAC 1 06-08-2010 03:16 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
Lennox Air Handler Fan Problems lehenson HVAC 7 09-01-2009 07:05 PM
Lennox air handler John C. HVAC 15 03-29-2009 08:24 PM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 04:53 PM
