Lennox AC Not Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 10:20 AM   #1
dmclean701's Avatar
Rewards Points: 152
Lennox AC not cooling
My AC stopped cooling last night. Blower still ran. No cold on the line at the compressor. I shut it off at the Tstat and waited about 30 minutes . When I turned it back on it cooled normally. A few weeks ago something stuck while set to 78 degrees, and I came home to a house that was about 66. Is this a Tstat problem or something else? It is a LuxPro, seven day digital programmable. Photo of data plate attached.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 07-08-2013, 12:20 PM   #2
Could be thermostat. Easiest way to tell is used a multimeter next time and see if the ac is getting low voltage or not.
Old 07-08-2013, 01:12 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
could B the tstat sticking or the magnetic contactor in the outdoor unit sticking. rare that they stick on/ (off yes) so I suspect the tstat ,95% chance is the problem.
Old 07-08-2013, 01:23 PM   #4
dmclean701's Avatar
Rewards Points: 152
I changed the Tstat with a new Honeywell 7 day programmable one. I had a problem, at first, following the instructions and it didn't work. I called the 800 number and amazingly enough was able to get right thru to a tech who told me that the C wire was not needed and to put the jumper back on the Rc - Rh terminals. This fixed it, I now am getting cool air ! Thanks for the help!
Old 07-08-2013, 01:26 PM   #5
Hvac Pro
yuri's Avatar
Good 4 U.
Glad 2 help.
Lennox Cooling Btu dbmet HVAC 1 06-08-2011 06:42 AM
Lennox XC21 Not Cooling - Please Help! honda03v6 HVAC 3 06-07-2011 07:00 PM
lennox heat pump cooling probs greaseking76 HVAC 1 05-28-2011 08:26 AM
lennox g20 whisper heat cooling mood cargom HVAC 0 09-25-2010 10:41 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
