Lennox AC/heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2010, 03:49 PM   #1
CCK
Lennox AC/heat pump
My AC is dripping from the upstairs overflow how to I correct the problem and make sure it drains normally?
CCK is offline   Reply With Quote
Old 08-07-2010, 03:53 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
Take a shop vac and suck out the drain pipe. Then open the unit upstairs and try run some bleach thru the drain to kill bacteria.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Lennox xp15 heat pump, power outage blip GEAF HVAC 4 04-02-2010 05:10 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
