Lennox Ac Condenser Not Running. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 07:50 PM   #1
Lennox ac condenser not running.
Is there a delay or breaker I can check on the condenser unit?
Jennil is offline   Reply With Quote
Old 08-04-2012, 07:54 PM   #2
Rewards Points: 582
need alittle more than that
Old 08-04-2012, 08:10 PM   #3
The unit is not cooling and condenser fan is not running. Wondering if there are some things I can check before I call a repairman.
Old 08-04-2012, 09:38 PM   #4
Rewards Points: 582
make sure breakers in panel box are on or reset....switch thermostat to cool and listen at condenser for a click..24 volt relay closing...that starts condenser....start there...
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 05:01 PM
Lennox G26 - blower stops running TJJP77 HVAC 11 12-05-2011 10:17 PM
Lennox HS29-311-3P Air Conditioner Not Working olgranddad HVAC 13 06-23-2009 12:39 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
HVAC Condenser fan not running DougE HVAC 4 09-01-2007 01:44 PM
