Old 01-17-2013, 09:43 PM   #1
Lennox 80UHG heat doesn't come on
I have a Lennox 80UHG furnace that quit working yesterday. I can turn the blower fan on by switching the fan from "auto" to "on" but the heat will not kick on when the thermostat is set to "heat." I have the temperature set above ambiant room temperature but nothing happens. There are 2 green diagnostic lights that flash slowly together supposedly indicating normal operation. Normally, the combustion air inducer will kick on, the gas will be ignited by an automatic igniter and then the main fan will kick on after a little bit. There's no clicking or fans coming on and all I can hear is a very faint humming sound. Can anyone help me diagnose the problem.
joshuaaap is offline   Reply With Quote
Old 01-17-2013, 10:42 PM   #2
Update: I tried "jumping" the furnace by running a wire from the W to the R terminals and the furnace starts up and runs just fine. Could there be a problem with the thermostat? the control board?
Old 01-18-2013, 08:57 AM   #3
Pull the thermostat from the wall and jump the same two wires again at the stat connection. If the unit fires then the stat is bad. That stat doesn't have batteries by chance does it?
danpik is offline   Reply With Quote
Old 01-18-2013, 09:56 AM   #4
Thumbs up
Yes, the thermostat has batteries. I changed them out but it still wasn't working. I had an old stat that I installed late last night in case the digital stat was bad and the furnace fired right up. I wish I would have posted here sooner and saved myself a lot of time fiddling with the furnace. Thanks for the advice anyway though.
Old 01-18-2013, 10:01 AM   #5
Roofmaster
Damn nice call DanPik ! What do you mean thanks anyway? The Guy nailed it pure and simple. Where I come from Thanks Anyway means nice try, but I got it myself.
" A lot of men build things, and a lot of things fall down "
jagans is online now   Reply With Quote
Tags
800uhg, furnace, no heat
I have not heat and we are freezing LENNOX G12 FURNACE NO HEAT. jovacano HVAC 3 11-07-2012 05:49 PM
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 06:18 PM
Lennox Heat Pump shuts down sully2 HVAC 47 08-19-2011 10:56 PM
Lennox xp15 heat pump, power outage blip GEAF HVAC 4 04-02-2010 06:10 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
