Lennox 80UHG Doesnt Blow Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 01:18 PM   #16
Send a message via AIM to stiksandstones Send a message via Skype™ to stiksandstones
Ok, just to confirm the lights. The led's flash green together, when thermostat is off, they flash slowly. When I turn on thermostat to get heat, the green lights flash quickly. So this says everything is A-OK.
But, after that inducer is blowing (I think thats what I hear spinning/activated) is shuts off after a couple minutes, then its just ONE led flashing green.
stiksandstones is offline   Reply With Quote
Old 02-26-2011, 01:21 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
did you check that MANUAL!!!!!!!!!!!!!!!! WHICH LED IS IT DIAG 1 OR 2? SEE MANUAL!!!!!!!!!!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-26-2011, 01:28 PM   #18
STOP YELLING!!!
if I am reading the codes correctly (led on the left (#1 ?)slow flash and led on right (#2 ?) OFF)
That is
"flame sensed without gas valve energized"
what now?
Old 02-26-2011, 01:33 PM   #19
Originally Posted by stiksandstones View Post
STOP YELLING!!!
That is
what now?
Going to take panel off now and make sure those LED codes are correct in regard to which one is Led#1 and #2, because the error I am getting is extremely rare according to google...so perhaps I am reading the board upside down? In that case the code would be:
"pressure switch open or has opened 5 times during a single call for heat:
OR blocked inlet/exaust ventOR condensate line blockedORpressure switch closed prior to activation of combustion air blower.
Old 02-26-2011, 01:36 PM   #20
ok, DS2 was slow flash, DS1 was OFF. so it is:
ORpressure switch closed prior to activation of combustion air blower"
Old 02-26-2011, 01:51 PM   #21
so that inducer motor seems to have a metal pipe exaust deal leading to the roof, I removed screws at the inducer vent pipe, looked inside for some immediate blockage, but IF something is blocking it, must be on the outside (dead bird as someone mentioned?) but this exaust pipe has some tricky joints/seams, dont know how to unattach them.
help
Old 02-26-2011, 01:51 PM   #22
AKA HVACTECHFW
OK. is the draft motor inducer operating? if so, then there is a ,typically orange, hose connected to the assembly. Remove the hose and using a small drill bit or paper clip ream out the port where the hose was, do this with the power off.
if the motor does not run, check for 120V to inducer with furnace on and calling for heat
IT IS WHAT IT IS
Old 02-26-2011, 01:54 PM   #23
The inducer motor pic you showed me...the BLACK WHEEL that spins, that is spinning, if that is what you are talking about.
Old 02-26-2011, 01:54 PM   #24
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
OY, it's like pulling teeth. 3 high priced Pro's trying to help. It doesn't get any better than that.
Old 02-26-2011, 01:55 PM   #25
Hvac Pro
yuri's Avatar
Yes, just follow our instructions verbatim and we will get you thru this. Try unplug the hole from the pressure switch tube at the part where it attaches to the furnace. Also remove the hose from the switch and blow thru it w/o being attached to the switch. DO NOT suck or blow into the switch irregardless of what you read on the net.
Old 02-26-2011, 01:57 PM   #26
AKA HVACTECHFW
if the black wheel is spinning on the back of the motor on its own, with out you spinning it, then yes it is running. Do as I said with the paperclip/drillbit.
IT IS WHAT IT IS
Old 02-26-2011, 01:59 PM   #27
AKA HVACTECHFW
very good point YURI, I hate reading that, it can ruin the diaphragm in the p/s
IT IS WHAT IT IS
Old 02-26-2011, 02:34 PM   #28
Reamed a tiny bit with a like-sized bit into that hole as you said, just used fingers to spin bit around to 'open' it up a bit, it looked a bit corroded/rusty even perhaps.
I HAVE HEAT!
Thanks so much you guys!
First, getting shower remodeling help in here and now this!
STOKED!
thanks!
Old 02-26-2011, 02:41 PM   #29
AKA HVACTECHFW
no problem, its what we do! Glad we could help!
IT IS WHAT IT IS
Old 02-26-2011, 02:42 PM   #30
Hvac Pro
yuri's Avatar
At 3X $100/hr for 3 Pro's you got a great deal. Pay it forward and help someone else with what you are good at.
Tags
heater , lennox , not firing
Lennox 80MGF - No Heat Thome HVAC 13 04-02-2011 11:45 PM
No heat but fan constantly running for Lennox G20R03E-75-3 sjz116688 HVAC 1 11-22-2010 07:08 AM
Lennox xp15 heat pump, power outage blip GEAF HVAC 4 04-02-2010 06:10 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
