#1 |
Lennox 80MGF3-75A Inducer Port Clogged
Hello,
When the t-stat calls for heat, the fan starts and then after about 1 min. it stops. Control board shows diag2 flashing, diag 1 off - which indicates pressure switch opened due to reduced air flow or a blocked condensate drain. When I remove the tube between the pressure switch and inducer(fan), I can blow on the tube to the pressure switch and it works. The inducer side port(nipple) is clogged completely. I tried to suck and pinch on the tube while starting the furnace, and it comes up so I know furnace is working. I tried to clear the port with a paper clip, thin nail. But it won't go through. Seems to be solid clogged. I wanted to know should the paper clip go all the way through? Any suggestion on how to clear the port? I also checked the vent to the roof and it's clear. Thanks. |
#2 |
Use a small drill bit
#3 |
Thanks for the information. I was able to use a small bit and drill through. The furnace fires right up.
I used a 7/16" bit. I think I should get a slightly larger bit and make the hole bigger so that it doesn't get clogged up again. |
| Display Modes | |
| Lennox Elite G51MP Series - Combustion Air Inducer Running | LennoxElite | HVAC | 6 | 10-06-2012 11:05 AM |
| Lennox inducer motor bracket | mmm97m | HVAC | 12 | 12-22-2010 11:42 PM |
| Lennox G43UF leak under air inducer | spricer | HVAC | 9 | 10-08-2010 07:06 PM |
| Yuri Help! look please - lennox g26 draft inducer motor drain? | mjt57 | HVAC | 6 | 02-06-2010 05:41 PM |
| lennox g26 draft inducer squeals | mjt57 | HVAC | 3 | 02-04-2010 05:13 PM |
