-   -   Lennox 80MGF3-75A Inducer Port Clogged (http://www.diychatroom.com/f17/lennox-80mgf3-75a-inducer-port-clogged-141457/)
jay235 04-25-2012 09:30 AM
Hello,
When the t-stat calls for heat, the fan starts and then after about 1 min. it stops. Control board shows diag2 flashing, diag 1 off - which indicates pressure switch opened due to reduced air flow or a blocked condensate drain.
When I remove the tube between the pressure switch and inducer(fan), I can blow on the tube to the pressure switch and it works. The inducer side port(nipple) is clogged completely. I tried to suck and pinch on the tube while starting the furnace, and it comes up so I know furnace is working.
I tried to clear the port with a paper clip, thin nail. But it won't go through. Seems to be solid clogged. I wanted to know should the paper clip go all the way through? Any suggestion on how to clear the port?
I also checked the vent to the roof and it's clear.
Thanks.
Marty S. 04-25-2012 11:21 AM
Use a small drill bit
jay235 04-25-2012 01:11 PM
It worked.
Thanks for the information. I was able to use a small bit and drill through. The furnace fires right up.
I used a 7/16" bit. I think I should get a slightly larger bit and make the hole bigger so that it doesn't get clogged up again.
carmon 04-25-2012 06:00 PM
I would not make hole bigger..... clean it once a year and you will be fine...:thumbsup:
