Lennox 80MGF High Limit Keeps Tripping After 1minute - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 09:01 PM   #1
Lennox 80MGF high limit keeps tripping after 1minute
Then shuts off flame. It trips before blower fan comes on. We just replaced high limit sensor today. The exhaust chimney in that 1 minute that the burners are on gets really hot. Can't put your hand on it. Any help would be appreciated
jevon77 is offline   Reply With Quote
Old 11-06-2012, 09:17 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
The circuit board may be faulty and not turning the fan on properly. Turn your fan to ON at the thermostat and see if it keeps running ( if you have AC).
Old 11-06-2012, 09:27 PM   #3
The fan does not run when turned to on position.
Old 11-06-2012, 10:17 PM   #4
Hvac Pro
yuri's Avatar
Could be a bad circuit board or fan motor or motor capacitor.
Lennox Limit Switch / Watchguard Issue shaneali HVAC 4 02-13-2009 07:16 AM
Comfortmaster RPJ II Open High Limit khalidmo81 HVAC 8 01-28-2009 04:47 PM
comfortmaker - 4 blink error - "open high limit switch" ericro HVAC 17 01-19-2009 10:36 AM
Trane Open High Limit Device mdcheddarhead HVAC 3 03-02-2008 06:43 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 12:33 PM
