Lennox 120-24v Transformer - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 02:42 PM   #1
lennox 120-24v transformer
I accedentally hooked the 120v wire to the 24v pin on the blower motor relay,now everytime I put in a new transformer it burns up.any sugestions would be great..Shawn.
zammy is offline   Reply With Quote
Old 08-08-2009, 02:53 PM   #2
Replace the blower motor relay which has a shorted coil (check the coil first with an ohmmeter) and protect your new 'former with a fuse unless the price of the 'former and the price of a fuse is close.
Finding the factory-specified dc coil resistance of this relay may be difficult. If there is a manuf. name on it you could call them.
Substantially less than 15 Ω sounds about right for a bad 24 vac coil. Also check for a short between the winding and the relay shell (ground).
If you know the 'former's Volt-Ampere rating you can get a new one and a fuse with holder way cheaper than what HVAC places charge, from Hosfelt, Digi-key, Mouser, Jameco or Allied Electronics.
Old 08-08-2009, 03:24 PM   #3
thanks
thanks for the info, I thought it might be that relay coil, because of what I did to it, it ohmed out at infinity 1. I will change it..thanks again. shawn.
Old 08-08-2009, 05:35 PM   #4
YOU GOTTA CHANGE THE BOARD.. the furnace will not be safe other wise. No way to know if other parts were compromised that could create unsafe conditions.
hvaclover is offline   Reply With Quote
Old 08-08-2009, 05:39 PM   #5
In that case something else is burning up the 'former and the Undead Gentleman is correct.
Old 08-08-2009, 07:01 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
He may be dead in the future but what the heck. It is a DIY world. Can you say welded limit control. ( I won't even mention a few other critical parts or how to test them). Ignorance is bliss my old boss used to say.
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 12:10 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
