Old 07-08-2010, 05:10 PM   #1
Lennok heat pump
HI i have two lennok heat pumps i bought used both were a couple of years old and i had them professionally uninstalled and checked. The problem is that the 2 ton unit is slight two small and the 4 ton is slighty to big. My house is 2000 square feet and the results of my energy audit states i need 1.9 tons of cooling and have 42000 btus of heat loss. I will be having this installed as a dual fuel with my keeprite propane furnace. My question is should i go with the 2 ton or the 4 ton
CHeers
Rich
Rearle is offline   Reply With Quote
Old 07-08-2010, 06:51 PM   #2
Lennok heat pump
Two ton will do better in cooling and the propane will take care of the heating when it gets too cold . Four ton is way too big.
Marty S. is online now   Reply With Quote
Old 07-08-2010, 08:17 PM   #3
Lennok heat pump
THX that was my thoughts aswell
Cheers
rich
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
