Left A Kleenex In Suction Line While Brazing - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 10:19 PM   #1
Unhappy
Left a kleenex in suction line while brazing
Ugh, I feel completely stupid. I made a big mistake while brazing in the suction line on a new evaporator coil. I had used a Kleenex to stop debris from getting into the line while cleaning the end, and I forgot about it and left it in while brazing. . I was flowing nitrogen through from the suction line, through the evaporator coil, and by the time the smoke had made its way through the coil, I was mostly done with the braze.
I did a test with the same pipe configuration and nitrogen flow on a scrap of pipe, and I found the charred kleenex gets blown somewhat back. I'm not too worried about that, that can be blown out. However, the tar from the charring condenses on the inside of the pipe, and even after blowing it out, still smells very strongly.
Is there any way to salvage the evaporator that now has tar condensed in it? My test pipe cleaned up relatively well with acetone. Is there any way to clean it, or do I need to replace the evaporator?
Thanks!
[Puts on ridicule resistant suit]
tesla500 is offline   Reply With Quote
Tags
brazing , contamination , kleenex , tissue
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Soil Line mapping/guessing JRoot Plumbing 2 01-25-2009 04:00 PM
suction line insulation? Lookin HVAC 8 06-06-2008 04:33 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
