-   -   Left cover on air conditioner (http://www.diychatroom.com/f17/left-cover-air-conditioner-104182/)
donnamohn 05-11-2011 06:00 PM
I accidently left the winter cover on my ac unit and turned it on for about 3 hours. The unit does not turn on now - the furnace turns on by the thermostat, but the ac unit doesn't turn on. What should I do? Thanks!
yuri 05-11-2011 06:11 PM
On most newer units there is a high pressure cutout safety switch inside the outdoor unit with a red reset button you need to reset. Can be hard to find and require covers etc to be taken off to get at. I would get a tech to do an annual service, check the freon level etc and reset it.
beenthere 05-11-2011 08:09 PM
First thing you should do is cross your fingers. Second thing you should do, is throw that cover away.
Then if you have a meter, check for open safeties.
yuri 05-11-2011 08:30 PM
I like it when the customer says "I never touched it" (cover is now off). BUT wait!! the teenagers turned it on and mentioned it wasn't working.:laughing:
Ka Ching, $95 service call.:thumbsup:
beenthere 05-11-2011 08:32 PM
Yep. Those covers make money for the company that makes them, and for us when they are left on when trying to use the A/c.
COLDIRON 05-12-2011 07:20 AM
Covers Blah!!!!!!! All they do is cause trouble especially when they are put on real nice and tight with all that condensation build up it ruins the innards with moisture. A/C units are like cars, boats, trucks, they belong outside. If I was to put a cover on at all it would be just to cover the top from excess snow and ice.
biggles 05-12-2011 07:58 AM
looking at it from a positive side:)...you blew a fuse in the disconnect box outside with the compressor tripping on HP or internal thermal overload...on the negative side:mad: you burnt the condenser fan motor out overloaded...burnt the compressor up windings exploded freon burnt acid...:furious: from the heat.check for 208V at the condenser disconnect.next fall just shut the disconnect off outside..only if you don't have a crank case heater on the compressor lets here back on the findings
gregzoll 05-12-2011 08:23 AM
If my neighbor had hers covered during Winter, it would not have had over a foot of leaf debris piled inside. Had to take the cover off, access panel on back, and the grid covering the coils to get all of the crud out of it.
yuri 05-12-2011 08:45 AM
All the metal inside the unit is galvanized so I have never seen one get damaged from "moisture". Cover or tarp some people use needs to be removed early in Spring so water does not sit in the bottom but I have never seen a problem due to having a cover on. Contactor and other parts are exposed to high humidity in places like Florida yr round so the moisture level is not an issue in my experience. On the newer high SEER units they have large fan blades and a load of snow can bend them so covering is a good idea.
biggles 05-12-2011 10:19 AM
the biggest saving is that the winter snow doesn't melt over the fan blades and all the water drips down and down the fan motor shaft...if you cover the condenser the life of it will be extended.even a plastic garbage can cover with a brick on top it something.you should hear and see what winter melt does to commercial rooftop condensers with 6-12-24 fans when they start for the spring load...and 480Vs ba boom:eek: and the building engineers aren't covering squat:wink: in the fall
beenthere 05-12-2011 05:23 PM
Got lots of old RTUs that have never been covered in their life, and still have the original condenser motors.
You must be talking about those (I'm not allowed to say the phrase) Trane units.
COLDIRON 05-12-2011 05:39 PM
Ha Ha good one Been.
chrisbane 02-26-2013 07:29 AM
Your Condenser coil must be burned off..you should contact service center
danpik 02-26-2013 08:41 AM
Another two year old post dredged up today
COLDIRON 02-26-2013 10:36 AM
Man this is some old stuff, guess the OP was looking for something to talk about.
To cover or not to cover?
It's good for reference.
