Leave "E" Wire Disconnected From Thermostat? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 08:03 AM   #16
AKA HVACTECHFW
Rewards Points: 1,208
Simply put... no, the nest is not the proper thermostat for your application. Most professional thermostats now have some sort of recovery feature that "learns" how your home heats and brings the temp up to the set temp at the programmed time. Nests claim to fame is that you don't have to program it for the time changes, but actually you are programming it and it takes a week or so to "learn" what times and temps that you make changes at the thermostat so you are programming it. There are other thermostats that do much more then the nest and allow you to control compressor and aux heat lockout temps. This is a better feature in that you can see more energy savings by controlling these options. Many thermostats now have access through internet protocol.
Again. The nest is not the correct thermostat for your application.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-29-2012, 03:42 PM   #17
An old Tradesmen
Rewards Points: 6,892
The brand and model number is important.
That thermostat is not an appropriate one for a heat pump with electric aux heat.
When you ask a question to over 100,000 people, your not gonna get just a narrow answer.
Old 10 wire Honeywell Thermostat prmillsjr Electrical 4 10-31-2011 05:14 PM
Line Wire & thermostat wire run? MNice HVAC 11 10-04-2011 08:52 PM
2 boilers thermostat wire installation... Handyman4u2fix HVAC 1 02-04-2010 12:50 AM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 07:14 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
