Old 09-18-2009, 05:29 PM   #1
Lear Siegler Wall Heater back clearance
HVAC Experts,
I have a Lear Siegler G350SW80 wall heater in a duplex i recently bought. The unit sits in a 2x4 wall, but it appears that someone had cut (hacked) away the sheetrock/plaster on the non-heat side. Does anyone know if the clearance requirements for these old heaters and if it is possible to sheetrock the back?
Thanks!
Steve Burke is offline   Reply With Quote
Old 09-18-2009, 09:22 PM   #2
You might check out the clearances from a Williams Wall Furnace site. They are a competitor, but their clearances are likely the same. At least you have a reference. Good luck
Flashheatingand is offline   Reply With Quote
Old 09-18-2009, 10:03 PM   #3
Hey Flashheatingand,
thanks for the insight...here is the URL for others who may have the same question http://www.wfc-fc.com/pdf/Monterey_T...t_Brochure.pdf
bottom line is that it looks like i can hang sheetrock on the backside.
Thanks!
Old 09-19-2009, 04:36 PM   #4
The drywall was probably removed in hopes of getting heat from the backside of the furnace.
SKIP4661 is offline   Reply With Quote
Old 09-19-2009, 05:22 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Gypsum, being inorganic, does not burn.
Paper yellows at 150C.
http://www.tcforensic.com.au/docs/article10.html
How long can you touch the backside of your heater after it's been on for a while?
no burn ever at 42°C(108°F)
burned in 30 sec at 54°C(129°F)
5 sec at 60°C(140°F)
1 sec at 71°C(160°F)
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
