Old 01-03-2008, 07:41 PM   #1
Leaky Steam Heat System
The Water in the gauge fell below adequate level (on the coldest night of the year). I awoke to frigid temps and refilled water the next morning...burner kicked right on and I assume ran off and on all day fine as it was nice and warm when I got home from work.... Big But, there were two pools of water on the basement floor leading to the system....no pipes leaking just water with condensation that is definetly from the boiler...
Turned up the thermostat and the system kicked on but is noticebly working harder - pipes shaking and noises in baseboard in the finished section of basement are noticeble. I've asked my Dad and he says to just watch it the next few days....He says this has happend to him if System is off in cold temps. True? Or do I need a pro?
New home owner
Cutlet is offline   Reply With Quote
Old 01-04-2008, 04:11 PM   #2
How much water is in the sight glass?
redline is offline   Reply With Quote
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 12:19 PM
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 09:26 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
