Leaky Steam Heat Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2007, 08:10 AM   #1
NJE
First off, Love the site....I have read a million and one posts on this site that has helped me do alot of things around my house. I have come a cross a problem now and need some insight. I have steam heat in my house and as of last week, I noticed that one of the pipes was dripping water.....Slowly......The pipe is in the ceiling in my basement so it is the pipe that is feeding the radiators upstairs. I still have yet to take apart some things to take a closer look but it seems that it is dripping from the middle of the pipe....No where near any of the connections. How is this possible???
NJE is offline   Reply With Quote
Old 01-27-2007, 08:27 AM   #2
Does it have pipe insulation in it?
Can you see the actual spot where it is leaking?
Is the leak at the top of the pipe, side or bottom?
redline is offline   Reply With Quote
Old 01-27-2007, 11:12 AM   #3
NJE
It has no insulation around it and the leak is at the bottom. I put my finger on it and I do not feel or see a hole or crack.....the water just condenses and starts dripping,,,so I am not sure where its coming from
Old 01-27-2007, 11:54 AM   #4
If the boiler is on then you would see it jet out like a tea kettle as the water reaches temp.
It could just be condensation. Or you may have a leak elsewhere and it is dripping down to this location.
Old 01-27-2007, 04:25 PM   #5
NJE
is it something I should be worried about???....Your right with the fact that it definitely does not jet out....Yet it just accumulates into a drop and the comes down.. I have no idea where the condensation would come from as it is warm inthe basement and the pipes are dry.....
Old 01-29-2007, 07:56 AM   #6
Can you post a photo?
Old 01-30-2007, 08:26 PM   #7
NJE
Its weird.....it stopped leaking....I am trying to put 2 and 2 together and seems that the days that it leaked, it was like 15 degrees outside and now that its around 30, its stopped....I still don't get it. I will try to post a pic tommorow
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 11:19 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Flushing a Steam Heat Furnance helpless handyman HVAC 2 11-06-2006 04:34 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
