Closed Thread
Old 05-16-2006, 02:06 PM   #1
Default Leaky furnace valve
I'll try this without pictures, since they all seem to be too big to post.
I have this leaky valve on my furnace, It's brass, cylindrical, about the size of a pill bottle, and has a knurled cap on the top that you can loosen and tighten. The valve is not in-line with any piping, but sticks out to one side near the pump. The valve leaks, it seems like this or another similar valve has leaked in the past, not too bad, a few drips every few minutes, but enough to be a bother. Is this something I can adjust, or does it need to be replaced?
billinak is offline
Old 05-17-2006, 09:40 AM   #2
Is this a hot water system?
Sounds like it is the air vent. Is it leaking at the top or the bottom?
These are inexpensive and you may find it easier to just replace it if the system is older. I would wait until the furnace is not in need of use, like during the summer to change the vent. If the smaller threaded stem breaks off at the bottom them it will take some more work to get the threads out.
With this leaking, making sure that you have make-up (feed valve) water coming into the system.
redline is offline
Old 05-17-2006, 01:32 PM   #3
The system was new in 2000, but was installed before we moved in. My understanding is that the boiler provides hot water for the Boilermate hot water tank, as well as the hot water baseboard heaters. I don't think supply should be a problem. The leaks are coming from around the cap on the air vent, does that mean the seal is bad, or is there some kind on pressure irregularity that is forcing the system to vent water?
billinak is offline
Old 05-17-2006, 07:06 PM   #4
The air vent removes air from the boiler. If air gets in the boiler system then it will makes noises as the water is pumped.
Over time the seal on these air vents fails and it is easier to replace the air vent. They usually sell for under $20.
Look at the web page below and see if your air vent looks like any of these.
http://www.plumbingworld.com/airelim...romsparco.html
redline is offline
Old 05-18-2006, 01:24 PM   #5
That's the exact one, the Gold Top Air Vent. I guess I'll change it out this weekend. It doesn't make a lot of noise (yet), but it's still leaking. Thanks for the info!
billinak is offline
Old 05-18-2006, 02:55 PM   #6
Be careful not to break off the threaded lower stem when you remove the old vent.
You may want to turn off the furnace so that the pump is not running.
When you do remove the vent, there will still be water pressure from the small pipe that you unthreaded it from (about 15 psi). Have the new one ready to thread back into the small pipe once you remove the old or water will drain out of the system.
redline is offline
Old 05-18-2006, 03:03 PM   #7
Thanks for the tips!
billinak is offline
Old 05-18-2006, 03:06 PM   #8
Hope it all works out for you.
redline is offline
Old 11-01-2009, 08:33 PM   #9
Default did changing the valve work- i have the same problem
did you run into any problems changing the air valve?
did you drain out the furnace as well as shutting it off.
dcam is offline
Old 11-01-2009, 09:11 PM   #10
Extreme DIY Homeowner
Scuba_Dave's Avatar
This thread is almost 3.5 years old
Original poster has not been back to this site in almost a year
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now
Closed Thread
More On This Topic
Hi! This John on behalf of Expert Village. In this video clip I will show you how to fix a leaky shutoff valve. Another common problem in households is that the shutoff valves will drip over time. There is packing inside of them that will become loose... Read More »
Hey gang, it's Don Golden here for Expert Village and the water is running and we've got to turn it off. I think we pretty much fixed our leaky little problem in here. So what we did was we took this old housing off and replaced our old leaky cartridge... Read More »
How to Do a Rough Duct Test
How to Do a Rough Duct Test by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to do a duct test in this house. We are doing a rough duct test on this house. Rough duct meaning literally that the house being built is in the... Read More »
So, on this bike we've got our valve, which is right up here, for our positive air pressure. And that's the one that we really want to use to effect our travel--how much sag we use the most. And a handy thing here is they've given me a tuning guide. So... Read More »
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 05:49 PM
who should pay my gas bill and furnace repair? papashaq HVAC 8 03-09-2007 07:36 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 07:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 11:23 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 03:19 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
