Leaky Chimney. Furnace Gone/water Heater Only - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 03:56 PM   #1
Leaky Chimney. furnace gone/water heater only
Didnt realize my chimney was in such bad shape.
http://imgur.com/a/B9zL9
Noticed water on the top of the cinder block in the garage.
Is there anything I can do just to get through winter?
Im afraid anything i put on there will just flake off with the next layer that delaminates from the brick.
jrz126 is offline   Reply With Quote
Old 12-16-2011, 06:13 PM   #2
DIY staff
Rewards Points: 7,174
Is the cap (concrete top) cracked?
Have you made any changes to the heating system in recent years?
Old 12-16-2011, 06:29 PM   #3
Rewards Points: 582
was wondering the same thing if maybe you need a fluelinner....did you think about using portland cement and coat the entire chimney weather seems to be holding ...roof don't seem that steep.....2-3 hour job..
Old 12-16-2011, 07:00 PM   #4
DIY staff
Moisture is getting into the bricks--from above--(cracked cap) or from inside--(cracked liner) or excess moisture from changing to a different furnace that no longer requires so large a flue.
Old 12-17-2011, 09:21 AM   #5
Furnace was upgraded to a HE in 2005 I think. I bought the place in 2008. Only thing venting out it has been the hot water heater. It was in the garage, but I moved it to the basement a couple years ago.
there was a crack in the cap. Previous owner must have patched it.
http://i.imgur.com/9WKGQh.jpg
Looks like there's quite a bit of moisture in there...
http://i.imgur.com/Z9fVfh.jpg
So it appears the flue is too big for the hot water tank. I'm adding a 100KBTU boiler for radiant heat for the basement/garage, wont run as often as the house furnace though. Will that help things?
or do i need to drop a few hundred on a separate liner for it?
Old 12-17-2011, 03:34 PM   #6
DIY staff
I'm going to move this to HVAC for you and add to the title--the moisture is a big concern.
Old 12-17-2011, 03:39 PM   #7
Rewards Points: 582
Can you tie new boiler and water heater togeother in basement ....then install new flue linner to handle both...ben
Old 12-18-2011, 05:27 AM   #8
DIY staff
Just a thought---replace the water heater with a high efficiency unit with a pvc vent and abandon the chimney---remove it in the spring and fix the roof.
Might be the cheapest in the long run---Mike---
Old 12-18-2011, 05:56 AM   #9
An old Tradesmen
Rewards Points: 7,268
Good idea.
Of course, if the OP is going to put a nat draft boiler in for radiant, he can't do that then.
He might want to consider a condensing boiler that direct vents, and an indirect water heater instead of a conventional boiler.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (12-18-2011)
Old 12-18-2011, 07:28 AM   #10
DIY staff
Thanks,Been there--I don't like adding my two cents in the HVAC area as my knowledge is limited.
And a bad bit of advice about a chimney from me could be costly--Mike---
Old 12-18-2011, 07:51 AM   #11
An old Tradesmen
No problem.
I understand, I have just enough knowledge about plumbing to get me into trouble. But not necessarily enough to get me back out.
Old 12-18-2011, 12:57 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
maybe its just me but shouldnt that flashing be on top of shingles?
plummen is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
chimney liner, excuse for propane furnace upgrade? bubbler HVAC 0 09-16-2011 07:58 AM
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 04:21 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
