Old 11-01-2009, 08:36 PM   #1
Default Leaky air valve on furnace
Leaky furnace valve
I'll try this without pictures, since they all seem to be too big to post.
I have this leaky valve on my furnace, It's brass, cylindrical, about the size of a pill bottle, and has a knurled cap on the top that you can loosen and tighten. The valve is not in-line with any piping, but sticks out to one side near the pump. The valve leaks, it seems like this or another similar valve has leaked in the past, not too bad, a few drips every few minutes, but enough to be a bother. Is this something I can adjust, or does it need to be replaced?
i have a gold valve sitting on top of the airscoop over the expansion tank on my furnace, it is leaking at a pretty good clip. i bought a new one, and need some advice on the install. do i have to drain the furnace before removing the old valve?
dcam is offline   Reply With Quote
More On This Topic
Hi! This John on behalf of Expert Village. In this video clip I will show you how to fix a leaky shutoff valve. Another common problem in households is that the shutoff valves will drip over time. There is packing inside of them that will become loose... Read More »
Hey gang, it's Don Golden here for Expert Village and the water is running and we've got to turn it off. I think we pretty much fixed our leaky little problem in here. So what we did was we took this old housing off and replaced our old leaky cartridge... Read More »
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
Well the next pieces that are part of the construction of the trumpet and many brass instruments: the tuba, the baritone, the euphonium, the French horn-- they all are made of cylindrical tubing that is bent. The bends are called slides, and slides are... Read More »
We have one more accessory. This accessory is a valve that will be attached to the end of the your beer bong. The point of this accessory is to prevent beer from leaking when filling up the contraption. When you are at the hardware store and picking out... Read More »
Leaky furnace valve billinak HVAC 9 11-01-2009 09:11 PM
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 3 08-18-2009 12:40 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 01:08 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
