Leaking Valve Stem - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 08:32 AM   #1
leaking valve stem
I have a Rheem 3 ton R410A split system. The valve stem on the suction side has a small leak. Is there a way to repair the stem with out replacing the valve or loosing the charge? It is leaking from around the stem on the service valve where you use a allen key to open and close the service valve
dohar9 is offline   Reply With Quote
Old 06-10-2011, 09:40 AM   #2
the stem can be tightened. there is a tool that will tighten it. may be able to get one at a bike repair shop. if the doesnt work the stem can be replaced...but you will lose all the charge then
cascadehvac is offline   Reply With Quote
Old 06-10-2011, 11:57 AM   #3
Thanks for the reply, but what I am talking about is not the schrader valve. It is leaking from around the stem on the service valve where you use a allen key to open and close the service valve. I hope I explained myself better?
Old 06-10-2011, 12:10 PM   #4
there is no easy fix for that. i would seal up the cap that covers the allen wrench port
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 07:52 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 05:03 PM
