Leaking Relief Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 11:06 PM   #1
I finally got around to bleeding my radiators today. Two had a little bit of air (30-60 seconds to bleed). 6 hours later, I was in the basement and heard the relief valve blow.
Last year, draining half the expansion tank cleared a slow drip from the relief valve. But today, it didn't stop the slow steady stream coming out of the relief valve. So I shut off boiler, the feeder valve, boiler in and out valves and still got water coming out. I assume the only place it could come from is the expansion tank. I opened up the relief valve and it finally drained out the remaining few gallons.
I plan on checking to make sure the expansion tank is empty in the morning and then turning on the system. Is there a particular order to opening the valves? Would you bother seeing if the valve is still leaking first or just replace it?
Tobinator is offline   Reply With Quote
Old 01-16-2011, 07:37 AM   #2
An old Tradesmen
Rewards Points: 7,808
An expansion tank should never be just half drained.
Post pics of your set up. Otherwise, no real way to tell you what order to do anything with your system.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 07:11 AM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 07:37 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
