Old 06-24-2010, 05:02 PM   #1
Post
leaking plenum box
I have a constant leak from the plenum box, what is the possible causes and is it something I can service myself and if not how costley is it to repair I'm on a limited budget.
zwhite is offline   Reply With Quote
Old 06-24-2010, 05:28 PM   #2
leaking plenum box
Assuming you mean a condensate leak there's a few things to do. Blow out the drain lines, take the drain pipe off of the coil and clean it. A cupp of bleach once a month keeps the crud from building up in those lines.
Check the filter, blower wheel and bottom side of the coil for dirt in case the water is from freezing up.
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
