Old 02-17-2007, 05:37 PM   #1
Leaking low water cutoff for steam system
Hi all, does anyone know how to fix a leaking low water cut off unit on a one pipe steam boiler. It's a Mcdonnell 67. Thanks, j in cleveland.
jincleveland is offline   Reply With Quote
Old 02-18-2007, 06:53 PM   #2
Hi Jincleveland, if I were you I wouldn't even bother repairing it, but would rather purchase a Brand New Water Cut off. If this thing decides to die on you, your boiler will run with no water, and it will definately level your house down. This device plays a very important part with your boiler, and one should not play around with..
helpless handyman is offline   Reply With Quote
Old 02-19-2007, 09:54 AM   #3
Slow down helpless, If it is just the valve on the bottom of the unit it can be replaced. Just make sure that the unit itself it working.
Pipes is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Adjust low water cutoff? STEPHENWANGEL HVAC 2 02-19-2007 05:23 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
