-   -   Leaking low water cutoff for steam system (http://www.diychatroom.com/f17/leaking-low-water-cutoff-steam-system-6554/)
jincleveland 02-17-2007 05:37 PM
Hi all, does anyone know how to fix a leaking low water cut off unit on a one pipe steam boiler. It's a Mcdonnell 67. Thanks, j in cleveland.
helpless handyman 02-18-2007 06:53 PM
Leaking water cut off...
Hi Jincleveland, if I were you I wouldn't even bother repairing it, but would rather purchase a Brand New Water Cut off. If this thing decides to die on you, your boiler will run with no water, and it will definately level your house down. This device plays a very important part with your boiler, and one should not play around with..
Pipes 02-19-2007 09:54 AM
Slow down helpless, If it is just the valve on the bottom of the unit it can be replaced. Just make sure that the unit itself it working.
