Leaking Hot Water Baseboard Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 02:08 PM   #1
Leaking Hot water baseboard heater
Two 6' baseboard heaters (25 years old) have developed cracks where the 1/2 inch copper supply meets the (appox.) 3/4 inch finned heat tube. Had to hacksaw through the end of the heat tubes so I'm left with a 1/2 in. copper tube which won't mate with the (more or less) 3/4 in. finned heat tube. (3/4 to 1/2 reducer won't work.)
Is there a copper, plastic, Sharkbite or other connecter which could solve this problem? Or maybe some technique I'm not aware of? I have average skills with a propane torch.
I'd hate to pull them both out and replace them before exploring the alternatives.
Thanks in advance for any help.
Ray2408
Ray2408 is offline   Reply With Quote
Old 06-15-2010, 04:51 PM   #2
An old Tradesmen
Rewards Points: 6,142
3/4 to 1/2" reducer works.
Theres more then one out there that has had that done to it.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Hot water heater leaking from pipe fitting and it seems top as well Omega1986 Plumbing 6 12-15-2008 09:49 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
