Leaking Furnace Exhaust Creates Musty Smell In Walls? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 08:00 PM   #1
Leaking furnace exhaust creates musty smell in walls?
Hi - new to this forum but I was hoping someone might be able to help me out. I bought my first house a year or so ago, and one room has always smelled a little musty. The smell kept getting worse, so I got overly ambitious today and opened up two of the walls to see whats going on. I don't see any mold really, but the smell is pretty strong inside the walls.
To jump forward a few steps, I figured out that the exhaust pipe from my furnace was rusted out underneath the house, and had been dumping the exhaust directly underneath the house right around where one of the the walls is for this room. The insulation above the vent was soaking wet when I went underneath to check and there are a few holes in the subflooring for pipes and such, so I'm guessing that's how the moisture came through into the walls.
My question is, if I can't see any obvious mold on the studs or subflooring, can I just let everything air out and dry and then re-sheetrock the room? Or do I need to take more serious steps to track down any mold that would be hiding in the studs or subflooring? I'm not very handy so I'd like to avoid that if possible Either way I've turned off the furnace and will be fixing the exhaust asap.
Thanks for the help!
camdunning is offline   Reply With Quote
Old 05-11-2013, 08:37 PM   #2
Too Short? Cut it Again!
I would first be worried about carbon monoxide getting into that room if the system had a busted exhaust system. You might think about adding carbon monoxide detectors because you may have dodged a bullet on this one.
The moisture may be from condensation and may go away. However, if the integrity of the plaster or drywall has been compromised you really should replace it. You should abate any mold or mildew.
The Following User Says Thank You to user1007 For This Useful Post:
camdunning (05-11-2013)
Old 05-11-2013, 10:06 PM   #3
Thanks sdsester. I do think I dodged a bullet on this one with carbon monoxide. I pulled out most of the old drywall and didn't see much or any signs of mold, but the room still smells very musty so I'm worried that mold may be in the studs or the subflooring and I just can't see it. I was thinking about giving it a few days to dry out (now that the furnace is off) to see what happens with the smell, but I don't want to put up new drywall and then have the mold come right back and have to pull everything off again.
Old 05-12-2013, 12:23 AM   #4
REP
Mold can only exhist in warm damp places.Fix the vent first ,replace the insulation and you should be good to go.
REP is offline   Reply With Quote
Old 05-12-2013, 01:23 AM   #5
Bill Kearney
Rewards Points: 1,174
Given the downside of mold growing and ruining anything new you put in there, I'd certainly consider having an air test done to see what's present, then decide.
wkearney99 is offline   Reply With Quote
Old 05-12-2013, 01:47 AM   #6
Rewards Points: 744
One of the products of natural gas combustion is water vapor.
Seattle2k is offline   Reply With Quote
Musty crawlspace smell coming into house tmpyankee HVAC 6 08-20-2015 09:46 PM
Furnace and Water Heater Exhaust dajate HVAC 2 01-27-2013 06:45 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 06:50 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
"Perfume" Smell from Furnace Vents Doc HVAC 6 12-29-2007 01:19 AM
